Ariston Margerita
  • #27372
    redchan
    Washing machine gives F-05 fault code but I can’t find this in user manual.
    Can anyone help tell me whats wrong or maybe how to reset machine.
    Can’t get door open and water still in machine as only gets to rinse cycle
    #213802
    hotpnt
    Re: Ariston Margerita
    Hi, F05 = your pump/filter is blocked, have you checked the filter??, make sure its switched off, unplugged & you have plenty of towels ready first!, (dropping the waste hose into a low washing-up bowl will remove a lot of the water from the drum before you start)
    #213803
    redchan
    Thanks for that I’ll try that tonight.
    Once unplugged will I be able to open door as I cant at minute even though washer switched off
    #213804
    hotpnt
    yep, with the power off the door will release after 1-2mins, would advise you to put drain hose in a bowl as mentioned first though, could be a lot of water above the door opening
    #213805
    redchan
    Cheers will try later, thanks for the help!!
