Re: Ariston Margerita AWD12S knob turning
To be brutally honest, what you have is an Indesit washer/dryer. It could be four or five years old by now which is on the high side age wise for one of these. 😥
It should be possible to set it to wash only but the electronics used in these appliances are about the most unreliable on the market so anything is possible and often leads back to a fault on the main PCB.
The only simple things you can check are, pump filter, motor brushes, loose wiring connections etc.
Be sure to remove the mains plug first if you do take a look.
The cost of new appliances is set to go through the roof due to the 40{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} drop in the value of the pound so it might be time to shop around for a suitable replacement ASAP. 😉
