ariston margerita not drying
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ariston margerita not drying
  • #34977
    Baldrick
    No warning lights, it does the cycle but the clothes are still wet.
    Can anyone help?
    #244643
    helo_75
    more info?
    does it get hot at all, is it cold? are they steaming?
    are they overly wet, or kind of dry?
    would help
    #244644
    Baldrick
    Re: ariston margerita not drying
    Hello
    No it doesnt get hot the clothes are wet still,
    I have looked at the forum before and checked the ducting removed the fluff had a look at what i think is the thermistor and i got a change of state upon testing. but is there a thermal fuse? and what sort of resistance measurement would i get from the heater element??
    KD
    #244645
    helo_75
    the thermal fuse is under the yellow sleeve on the top of the heater box
    should be closed circuit normally, if its open its duff
    same with element
    hope this helps
    plug out if your investigating
    #244646
    Baldrick
    Thanks very much i will give it a go now
    #244647
    Baldrick
    sorry but i have the heater box off and there is the two connectors to each end of the heater element. Half way down the coil is that the thermistor? or the thermal fuse?
    If it the fuse where is the thermistor??
    Confused of epsom
    #244648
    helo_75
    the thermistor is screwed into the top.. its round, black with a plug on the top with 2 thin wires coming out
    the thermal fuse is normally a link to the heater connection, held to the heater box by a clamp and 1 screw
    #244649
    Baldrick
    Thank you thank you
    The thermal fuse in the yellow sleeve was blown!!
    Your a saint
    Thanks again
    #244650
    That’s “Halo_75″ then……….. 😀
    helo_75
    i really hope you havent bypassed it……….
