Ariston Margeritha AL 128 D.. won´t turn on
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margeritha AL 128 D.. won´t turn on
  • #7734
    clandestine
    I have a problem with my washer dryer combo from ariston
    …..guess that won´t raise much eyebrows.
    It acted a little funny last week and the clothes came out somewhat
    more wet than usual. no dryer in that cycle.
    but last night when i got home and tried to turn on a machine
    nothing happend
    no red light
    no flashing red light
    no turning knob klicking
    nothing
    checked the socket and it has power alright
    but it won´t turn on.
    what can be wrong ?!
    Should i just put away my toolbelt and call for help ?!?
    Best Regards
    Joakim ….. (from sweden i might add)
    #124886
    clivejameson
    Re: Ariston Margeritha AL 128 D.. won´t turn on
    Hi Joakim
    If you’ve tried another appliance in the same socket and that’s ok then open up the plug to the washing machine and check that. The fuse may have failed so you could try another one although beware that this may fail as soon as you switch on. If it does, or the machine still doesn’t work then you will require an engineer to investigate…it may have a faulty on/off switch, a faulty door lock, or a component inside may have an earth fault.
    Clive
    #124887
    Joakim – either very simple – on/off switch failure, or rather complicated – computer board failure. Given that you have commented that the machine was not working correctly before, I would think the computer is the more likely problem.
    Time to get the engineer…….
    clandestine
    Well a fuse in the fusebox went out so i replaced that
    and tried a blowdryer in the socket wich worked fine
    then plugged in the ariston once again and ….. nothing.
    any idea how much this will cost to repair in parts.. worst case scenario ??!
    thanks for really fast replies.
    i guess i will go and make the call now.
    // J
    #124889
    clandestine,
    I sounds like the main Computer Board has failed I’m afraid 🙁
    It can be repaired here in the UK using :-
    http://emwelec.co.uk/
    Otherwise a new board is very costly and may be uneconomical to repair 😥 .
    :zap: DO PULL THE PLUG FIRST before removing the back panel :plug:
