No, it’s an absolutely horrible job. Cross piece on the back has to come out. If there is any wear on the drum shaft, you have to buy a new tank assembly. Handle the current one with kid gloves, the back panel has the structural properties of bacofoil.
thanks for reply i have got the bearings of (whith the help of a big hammer amd slashed wrists) the spider is aloy and the shaft is 30 mill dia
is this the correct bearing kit you have listed (ar051050)
Regards Mike
