Re: Ariston Margharita AWD 12S not draining water
When cleaning out the filter you need to get right into the rear chamber where the impellor is. Hands, knees and a torch. If this is clear and the impellor will turn freely with a “pinging” action, you probably have a failed pump.
http://www.ukwhitegoods.co.uk/modules.p … cts_id=392
should be the one you want.
If you’re not sure, check repairs@ or Directories for a UKW repairer in your area.
Power off if doing anything other than checking the filter.
