Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Ariston margherita 2000
- This topic has 11 replies, 4 voices, and was last updated 17 years, 1 month ago by
colin62.
February 17, 2009 at 11:39 am #43539
colin62
ParticipantHi I have an A1435 advantage. it has the dreeded knob clicking the power LED flashes twice. can anyone help me.
February 17, 2009 at 11:42 am #277602iadom
ModeratorRe: Ariston margherita 2000
2 flashes indicates a main motor problem.
Could be loose wiring, faulty motor but sadly is often caused by main PCB failure. 😥
February 17, 2009 at 11:57 am #277603colin62
ParticipantRe: Ariston margherita 2000
thanks will check out the wiring , however the drum still spins does this narrow it down
?February 17, 2009 at 3:52 pm #277604iadom
It could be a loose module connection, they are very flimsy.
The odds are against you with this machine though, the Indesit electronics are known to be flaky to say the least. 😥
February 18, 2009 at 9:15 am #277605colin62
Hi thanks for the pointer it was a dry jiont on the control board looked like a relay terminal a quick touch up with a soldering iron and solder and the beast is back in action! thanks once again.
I do have another question I am in Australia and it is very difficult to get spares for european machines does anyone know a uk supplier who will post spares to Oz.
😀February 18, 2009 at 9:39 am #277606iadom
Didn’t spot the Antipodean connection. I will move you post to the ‘Darn Under’ forum, 😉 perhaps someone who posts from Oz will know.
February 18, 2009 at 7:19 pm #277607Penguin45
ParticipantFebruary 19, 2009 at 6:01 am #277608bigsmokepiker
Depends which Brand of Washer
Let us know what your after & I can Point you in right direction
Some wholesalers will charge an arm & a legFebruary 19, 2009 at 6:50 am #277609colin62
Hi The model is an Ariston Margherita 2000 A1435. I am after shocks and drum bearings. The machine emigrated with us 4 years ago so its a uk spec
February 20, 2009 at 2:07 am #277610bigsmokepiker
Ariston 1300762219
Bearings Are Standard from Any Bearing Supplies
Shaft seal & shockers You would have to get from Ariston
Try UK Parts as well, they may well be cheaperFebruary 21, 2009 at 3:12 am #277611colin62
thanks 😀
February 22, 2009 at 1:40 pm #277612Penguin45
Bearings are 6205 and 6204. Shaft seal is p/no C00082696.
