Re: Ariston Margherita 2000
Kiddi,
The actual fault refers to a ‘water level sensing problem’, but you may read into that what you will because it is only a ‘guide’ as to the fault. Assuming indeed that your machine isn’t blocked (i.e The pump and sump trap) Then it could be a connection failure with the Control Module??
You say you have just moved house, therefore this fault may be due to transit damage in some way?? Did it work OK at your previous house and not at the new location then?( If that’s the case the contacts within the circuit board may well be the fault)
