Home › Forums › Public Support Forums › International Forums › Australasian Appliance Forum › Ariston Margherita 2000 AL109X problem
- This topic has 5 replies, 6 voices, and was last updated 21 years, 5 months ago by
terje.
October 26, 2004 at 7:15 pm #6634
terje
ParticipantI have an Ariston Margherita 2000 AL109X, which will sometimes stop after a few minutes, and sometimes not even start. The LED error code is 6 blinks. It recently had its electronics replaces (1 blink error code), and has functioned fine for a few weeks since that. Any ideas of what this problem is? Also, it will sometimes blow its fuse almost as soon as the motor starts turning.
TK
October 26, 2004 at 11:12 pm #118758Penguin45
ParticipantHi TK,
6 flashes is a “management error” – fault on digital control board. The single flash relates to a motor speed control problem. SO – the clue is the motor blowing fuses – this will need to be replaced, as will the control board.This whole thing smacks of a misdiagnosis and you should contact your repairer immediately; your new board has failed because of the motor problem.
Was this Merloni Service or a private repair – we’d love to know.
Penguin45.October 8, 2008 at 8:48 am #118759dannygwapo
ParticipantRe: Ariston Margherita 2000 AL109X problem
excuse me, i just want to ask if you have a manual for Ariston Margherita 2000 AL109X. can u please send me the manual. here is my email dpalonio@yahoo.com.
and what if it blinks 5 times and the dial turns and makes a clicking sound? what error is that?
November 7, 2008 at 11:27 pm #118760admin
KeymasterRe: Ariston Margherita 2000 AL109X problem
Can I ask too? 🙂 please
manual for me
aniaplul@gmail.comNovember 7, 2008 at 11:34 pm #118761iadom
ModeratorRe: Ariston Margherita 2000 AL109X problem
It may be a good idea to post your question in the Oz forums dannygwapo :wink.
Your model number is not recognised by our UK software so the links to downloadable manuals would not be much use.
5 flashes on UK models suggests the pressure switch is stuck on full. Often caused by a pump or filter blockage.
If you remove the plastic kickstrip at the bottom, front of the machine you should find the pump filter. Remove this and you may find the cause of the problem.
EDIT. I have moved you to the Oz forum, I’m sure the OP won’t mind, it was in 2004 after all. 🙂
November 9, 2008 at 9:27 pm #118762bigsmokepiker
F5 Error is As Iadom suggests
5 Flashes as per UK models
Check your Pump -
