Re: Ariston Margherita 2000 AWD 12 Advantage-does not dry
Element or thermal fuse most likely culprit. Possible wiring problems. If the thermal fuse has failed, the condenser housing on the back of the drum will be choked with fluff and will need to be cleaned.
