Ariston Margherita 2000 AWD12 Advantage
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita 2000 AWD12 Advantage
  • #28999
    davewatts2000
    Ariston Marherita 2000 AWD12 Advantage – I dont think my machine uses / takes in enough water… I know its an energy efficienty machine, but im not sure there is enough water in it. Does anyone else feel the same ??? Is there any way of adjusting it ?
    Dave Watts
    #221047
    Re: Ariston Marherita 2000 AWD12 Advantage
    You normally can’t see the wash water in a modern autowasher. To achieve the energy ratings, levels have become lower and lower. The less water, the less there is to heat = less energy used.
    However it does mean that instead of moving the clothes through the wash solution, you are now forcing the solution through the clothes – a muchy slower process.
    If your complaint is really that you are getting poor wash results, this is the usual reason:
    http://www.ukwhitegoods.co.uk/modules.p … ge&pid=181
    Cleaning out the soap drawer and box and the filter regularly helps as well.
