Ariston Margherita 2000 AWD12 Advantage – Door handle broken
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita 2000 AWD12 Advantage – Door handle broken
  • #30742
    Rumbl3r
    Hi all
    Can anyone tell me how to open the door so I can get the washing out with the handle broken? It just flops around 🙂
    Once the door is open I guess I can work out how to replace the handle etc., but I need it open first?
    Also, can anyone tell me the part number I need?
    Thanks in advance.
    #228247
    Re: Ariston Margherita 2000 AWD12 Advantage – Door handle br
    The only way from the front is to try and get hold of the latch with long nosed pliers or hook something round it if you can see it. Also possible to release from inside as long as you remember to remove the mains plug.
    Top off and reach down inside the front of machine.
    Need full model number from rating plate to identify the correct door handle kit.
    Is it AWD12UK or AWD12SUK ?
    Rumbl3r
    Thanks for you help, door is now released! Had to do it from the top and was easy once I knew which bit moved which way 🙂
    Serial number label inside the door says: AWD12UK
    Once again, thanks.
    #228249
    C00116580 is the part you require, an e-mail to spares@ukwhitegoods.co.uk should do the trick.
