Ariston Margherita 2000 AWD12 UK
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita 2000 AWD12 UK
  • #32154
    swarduk
    Hi, My machine programme dial keeps turning round, and the error code it appears to be reporting is number 4 (counting the flashes). Can someone tell me what it could be?
    Have checked and cleaned the filter, checked the inlet hoses are not blocked, and checked no kinks in the waste pipe. The machine just pumps out water whilst the dial is turning round, so seems like water in/out is working okay. Also if I put it onto a drying cycle, the drum turns for a short while so looks like the drum/motor is okay too.
    Any ideas what fault code 4 means?
    Thanks, Steve.
    #233835
    Re: Ariston Margherita 2000 AWD12 UK
    swarduk wrote:Any ideas what fault code 4 means?
    The water level switch jammed on empty is what it means. So possibly you may need a new Pressure Switch or at least check out the water level system firstly. Pressure Switches are a regular known weakness and can damage the main control module when they fail too? 😥
    With Ariston the problems go on and on and on and on….. :rolls:
    #233836
    swarduk
    Thanks Martin,
    How would you recommend getting this fixed? Ariston have quoted me £95 to come out and repair it, or do you know a better option?? (P.s. I’m in the Surrey area)
    #233837
    vanstrada
    Why do you say the problems go on and on . Is it not a reliable brand or machine ? Help in Australia
    #233838
    rowdyrobert161
    blow into the pressure switch, if this is ok then try clearing the memory, place dial on any spot at end of cycle, turn machine off, then on. select drain cycle, if machine drains then select another spot re do previous instructions, then select desired wash program
    #233839
    swarduk
    Thanks, I’ve tried resetting the machine in various ways, including how you describe, and it still seems to go into error mode. Where is the pressure switch? Is this something for an engineer, if so is the Ariston quote of £95 reasonable??
    Cheers.
