Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston Margherita 2000 Problem
- This topic has 6 replies, 4 voices, and was last updated 20 years, 2 months ago by
plasticpaddy.
February 7, 2006 at 5:19 pm #15468
plasticpaddy
ParticipantHi folks,
My Ariston doesn’t heat up the water. Nor does the dryer heat up.
Other than that it does go through the usual washing/dryer cycle.
Could it be a thermostat problem?
KirkFebruary 7, 2006 at 7:11 pm #163682Penguin45
ParticipantRe: Ariston Margherita 2000 Problem
Kirk, they’re all “Margy 2000s” – which one have you got? Model number in corner of control panel.
Penguin45.February 17, 2006 at 2:00 pm #163683plasticpaddy
Hi Penguin45,
Sorry for taking so long to answer.
My machine is a ‘AWD12’.
I’m so broke that I need to find out as much as I can about the fault before calling out an engineer! So any help is gratefully received.
KirkFebruary 17, 2006 at 3:44 pm #163684Goatboy
plasticpaddy wrote:Other than that it does go through the usual washing/dryer cycle.
So it doesn’t go into fault mode?
If it’s not heating the water on wash, it should be flashing it’s light at you, and have the programmer knob rotating 😕
February 24, 2006 at 5:38 pm #163685plasticpaddy
No flashing lights or knob turning!
Curiosier and curioser.
cheers
KirkFebruary 24, 2006 at 6:11 pm #163686Bryan
plasticpaddy wrote:No flashing lights or knob turning!
Kirk , it`s very unlikely this washing machine is completing its cycle if not heating the water , remember it`s only at the initial wash when the water is heated and all rinses are in cold water.
Try it on a 90C program and you should certainly feel the heat.May well be that the dryer is faulty and not giving you heat but this is a seperate issue and an experienced engineer would be my advice.
Check repairs@ on the left of this page.
Power off if you do decide to look further yourself :zap:
Bryan
February 25, 2006 at 9:02 am #163687plasticpaddy
Thanks Bryan.
The knob definitely doesn’t turn, however the light does continuously flash at the end of the washing cycle, but not in any ‘groups’ as if it were morse code. It just blinks regularly.
Thanks again for all your help folks. Have been recommending this site to the ‘technically challenged’ at the office.
I’ll be getting that engineer.
cheers
Kirk
