My washer dryer has just developed this problem.
it goes to spin during the cycle and then the pump runs.
Water comes from the waste and the drum turns.
It does this for abot 10 seconds then the drum stops.
The pump keeps working.
The dial just keeps going round and it flashes in groups of 8. Error code 8?
They could cost you over £100.00, if you give us the full model number ( not 2000) and serial number we could be more precise but TBH, you really need to decide if it is worth spending that sort of money on an Indesit machine. If you do then it would be advisable to get the machine checked out by someone with the required skills first.
