Ariston margherita A1324 HELP Please
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston margherita A1324 HELP Please
  • #33424
    paulwgun
    Ive fixed my m/c before using this forum and wonder if anyone can help again
    Put m/c on it fills and then stops nothing else happens, could it be a heater fault? is there a list of fault codes for reference
    #238575
    Re: Ariston margherita A1324 HELP Please
    Check carbon brushes in drive motor.
    Power off, of course.
    paulwgun
    Brushes seem ok, once it fills should heater be getting power? as there is no power going to heater ,but heater element is ok according to meter
    #238577
    The only fault that won’t give a fault code is the motor out of circuit. Brushes, wiring, module are all possibilities.
    Heater will start to receive power several minutes into the cycle, not immediately after fill.
    Please don’t live test…. There is no real need and it’s bl@@dy dangerous.
    paulwgun
    Many thanks for your help, my hands no where near the cables on live test. Probes are inserted in to spade connectors before i switch on power and power off before removing probes
    Wife has now had enough as washing is piling up and gone to get a new m/c
