my Ariston Margherita A1435 is misbehaving. i think i know what the problem is but am not sure what to do from here or which spare part i need. the machine is fine for a few washes then stops and doesn’t get rid of the water. i then get the water out and open the filter part behinde the kick plate at the bottom. the problem is that the rotor (not sure if that’s what it is called) comes loose and is no longer on axis and is not moving the water to where ever it moves it. it can get it back into place and it will finish that cyle and one or two more but then the same happens to the “rotor”.
My question would be how this rotor is held in place. is there anything i can tighten or do i need to replace the part (which part?).
Re: Ariston Margherita A1435 pump rotor (?) problem
is this fairly streight forward (take old out put new in)? no way of repairing the old? just had the brushes changed and am wondering if the machine is on it’s way out (or is the pump just a wear and tear thing?) on the spare part of this site there are two Ariston pumps anyone know which one of these i’ll need to get.
