Ariston Margherita A1535 Advantage – pumps while empty
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita A1535 Advantage – pumps while empty
  • #17268
    Ukspace
    My machine goes through the complete cycle, or so I think, until it gets to the rinse cycle.
    It fills with water and goes through the spinning routine before draining the used water but this is as far as it goes. The pump runs for about 3 minutes and then the programmer clicks round continually.
    I have already checked the outlet hose, the termination under the sink into the main waste pipe and the filter at the base of the machine. I have also opened the filter compartment at the base of the machine whilst the pump is trying to pump water that isn’t in the machine out and all appears okay.
    I have read other posts indicating a water level switch and I will probably try to check this out if you agree this would be the next step.
    How much would this part be for my machine with postage?
    #173564
    Re: Ariston Margherita A1535 Advantage – pumps while empty
    When the control knob starts to click round, the mains indicator light should flash a set number of times then pause, then flash the same number again and again. If it is flashing you need to count the flashes and report back as this is an error code, not always a reliable one but it may give us some idea.
    #173565
    Ukspace
    Probably the obvious one considering the fault description. I am getting five flashes when the fault appears. I have read that this indicates a water levelling problem.
    Now where do I go?
    #173566
    Five flashes does indicate a pressure switch fault, you have to bear in mind that these fault codes can be somewhat ambiguous to say the least. In fact it may not be the switch but a blockage in the pressure hose or pressure chamber.
    The pressure switch is not over expensive but your machine can have two different types. We would need the full serial number to identify the correct one.
    #173567
    Ukspace
    Is that the number inside door?
    #173568
    Ukspace
    The serial number is 211122233 * 80280690000.
    I think that’s the correct number. It came off the sticker inside door.
    #173569
    Dave_Conway
    Yep, that’s the one, the pressure switch for this version is part number C00086660 at £10.14 plus carriage.
    An email to spares@ukwhitegoods.co.uk please if required 🙂
    As iadom says though, it’s not conclusive this is the problem and an engineer would be the best bet if you’re unsure, the repairs@ link below should provide one, power off if repairing yourself please :zap:
