ariston margherita A1635
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ariston margherita A1635
  • #10167
    mickk
    could anybody help with a problem , the washer seams to have stopped in the middle of a wash cycle the door lock light is on , but the door will open . But the power switch will not work , it will not stop in and if pressed the led does not light up .
    i would be greatful for some help on this mik
    #138686
    Re: ariston margherita A1635
    mickk wrote:But the power switch will not work , it will not stop in
    That’s your problem then, the double pole on/off switch needs replacing (there are 2 different types fitted to that machine too, which may cause some difficulty with identification 😕 )
    If you try Repairs@ we may have someone in your area that can sort it quickly and cheaply 💡
    #138687
    mickk
    ok thanks for your help will try to find which it is
    #138688
    mickk
    ok checked the power swithch now got the switch to opperate on off but
    the light still comes on , on the door switch when power is on and the door still opens . then disconected the door switch from the supply and the led is still on .
    thankyou mik
    #138689
    Mik,
    I am a little confused from your report as to exactly what is happening here. 😕 (I cannot see your machine and can only diagnose from info given after all) 😉
    So, first you said the on/off switch would not stay in! That indicates pretty conclusively to me that the switch is faulty…OK?
    Now you say that the on/off switch works :con:
    How can you be sure that it works fully? You may have just forced it to stay in, though that would not guarantee it is now working. ❗
    So my conclusions so far has to be that the on/off switch is the fault whilst not ruling out the possibility that the door lock switch could be faulty. One more thought 💡 ….the door handle and door striker are operating correctly are they to ensure they locate into the door lock securely?
    #138690
    mickk
    took the top off looked at the switch and didnt force it just checked it and now works fine as the power comes on and off as only two blue wirse go into this and they make or break the circuit . as this works fine then i looked at the door switch this i took off and checked to see it was not sticking . when the power is on the light of the door lock is on this is the case even when the lock is dissconnected. also when connected and the door is opperated the light still stays on and nothing happens when put on a program eg spin
    #138691
    In that case it most likely is the Door Interlock I would think?
    Although I’m still worried about your first statement that :
    mickk wrote:but the power switch will not work
    On your machine there are 2 variants ‘Door Interlocks’ the earlier type is black and Part No: C00011140 and the later one is grey and is Part No C00085194.
    If you want to take a chance and fit a new one then you may order by email to : spares@ukwhitegoods.co.uk stating the correct part no 😉
    #138692
    mickk
    sorry to trouble you but on further investigation although the on/off switch opperates (now stops in ) the on/off led does not light just the doorlock led glows this is dull so suggests to me as power is on somewher
    and when the doorswitch is opperated (eg shut )the led glows brighter.
    sorry for the earlier mixup
    thanks mik
    #138693
    Mickky my boy 🙂 ….read and take on board my very first comments :lesson:
    Martin wrote:That’s your problem then, the double pole on/off switch needs replacing
    #138694
    mickk
    switch tested and is working fine (been tested with multimeter)
    so dont know if this helps
    #138695
    Sorry then Mickk, but the advice given by me has clearly not helped in solving your problem 🙁 And unfortunately we as trade members are not obliged (for legal liability reasons) to suggest any member of the general public should test,check or inspect any electrical components within any appliance….sorry mate 🙁
    Therefore I strongly suggest you get one of our recommended engineers 😀 to do the repair for you by clicking on this link:- Repairs@
    #138696
    mickk
    ok thaks for your help will get tech to look at it
