ariston margherita a1635
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ariston margherita a1635
  • #27653
    leftluggy
    hi,
    i’m hoping that you will be able to help me solve our problem with the above washing machine. i know you have said to check through the forums but i just cant find the same problem to the same machine. sorry.
    the washer has stopped half way through the cycle, and the control dial just keeps going round with the power light flashing slowly (not sure if this info helps, but i think it was 7 flashes to a full turn)? if i put the control dial to the rinse, it does nothing but the power light keeps flashing.
    also do you have a contact number for ariston, so i can see if they still hold a manual for this machine, as i have tried searching the web and failed.
    thank you
    #215044
    Simon46
    Re: ariston margherita a1635
    Count the flashes in between the pause. It will keep repeating.
    Regards
    Simon
    #215045
    leftluggy
    hi simon, it was a definate 8 flashes, when it reached the rinse cycle the dial stopped but the light continues to flash?
    thanks frankie
    #215046
    8 flashes = New Heater and/or Main Circuit Board 😥
    #215047
    leftluggy
    thank you so much for your time and help, is it possible to buy a new main board? i did look in the parts section and found the heater, but not a main board?
    thanks frankie
    #215048
    leftluggy wrote:thank you so much for your time and help, is it possible to buy a new main board? i did look in the parts section and found the heater, but not a main board?
    thanks frankie
    It is possible, but is it worth it? New board plus eeprom will be around £100.00 and may not cure an 8 flash fault. 😥
    CraigMc
    I have the same 8 flash fault, however i can still use the quick wash cycle. It only resorts to the clicking round and the 8 flashes when i use a longer wash. Does this mean it is more likely to be the heater and not the main board?
    Or really do i need a new washer??
    #215050
    The heater relay this fault code refers to is on the main board. It is a fault code that can actually arise for several other possible faults such as pressure switch, wiring connections etc, etc. 😥
    budge
    crickey mines been doing this too lately!!!
    ive just stopped the cycle and restarted it until its finished the cycle 😯
    #215052
    CraigMc
    Thanks Jim for the reply.
    By wiring connections, could it be a possibility that some wires may have come loose through vibration and caused this?
    I know it’s a long shot?
    #215053
    CraigMc wrote:By wiring connections, could it be a possibility that some wires may have come loose through vibration and caused this?
    All wiring connections on this machine are suspect, especially the module plug-in connectors and the NTC (thermistor) wires. Intermittent ‘8 flash’ errors can be the result of bad connections or faulty relays on the main board.
    They are a pain in the Ar-is-ton that’s for sure. :rolls:
