Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › ariston margherita a1635 error code 3 ?
- This topic has 7 replies, 4 voices, and was last updated 20 years, 2 months ago by
rob301270.
January 26, 2006 at 5:32 pm #15158
rob301270
ParticipantHi I have an ariston margherita a1635, the knob turns during which the led flashes 3 times then stops, then three times then stops etc etc, can anyone tell me what this error code relates to?
Thanks in advance RobJanuary 26, 2006 at 6:00 pm #162430Dave_Conway
ParticipantRe: ariston margherita a1635 error code 3 ?
Temperatre control problem, possible poor connections or a sensor failure.
Power of please if checking yourself :zap:
It shouldn’t be an overly costly repair either so if you need an engineer, check the repairs@ link below 🙂
August 24, 2009 at 11:25 am #162431ghowe79
My Ariston has started doing this (except when there is no load in the drum)
I have had the probe out and it measures ~22k at room temperature.
Checked wiring and everything seems to be on properly.What should I try next?
August 24, 2009 at 3:41 pm #162432iadom
ModeratorRe: ariston margherita a1635 error code 3 ?
A new washing machine. 😉
Sadly if all connections are OK and the NTC checks out then there is a strong chance the main PCB is faulty, Indesit electronics are notoriously flaky at the best of times.
You may be able to get the board tested/repaired at places such as EMW but a new one with the required smart card and card reader is just not owrth it.
August 24, 2009 at 4:54 pm #162433ghowe79
Assuming PCB, is there a componant of choice that likes to go bad?
Are there any board schematics I can use for fault finding?Being somewhat electronically minded, and somewhat skint, I’m keen to explore the option of repair.
August 24, 2009 at 4:59 pm #162434iadom
No board level information of any kind available.
August 24, 2009 at 5:06 pm #162435ghowe79
That is, unfortunate 😥
August 26, 2009 at 8:34 am #162436ghowe79
Machine repaired! 😀
Long story short, I did some (extensive) testing and determined that the PCB basically worked. It turned out to be the wire that goes in to the connector on the temperature probe had broken inside the connector.
Remedial action taken!
