S/N 101127372
When I select a program, it starts taking water for 1 or 2 seconds then stops for a minute and then starts pumping water out and rotate program selector continuously.
When the program selector is rotating the power LED is flashing very fast 3 times with 10 seconds pause between flashes.
I have tried resetting the machine using info from other topics.
I also checked filter, water pump and hose.
No success so far.
If I leave the machine alone for 2-3 hours, it sometimes starts working properly but half way through spin cycle it starts to spin very slowly and starts flashing its LED and rotating program knob as I mentioned above.
Thanks,
Oleg.
