Ariston Margherita ALD12 3 Flashes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita ALD12 3 Flashes
Viewing 15 posts - 1 through 15 (of 18 total)
  • #25968
    japn
    I have a Ariston Margherita ALD12 which the dial turns continuously and 3 Flashes on the error code. what does this mean and how do I trace the fault please.
    #208276
    helo_75
    Re: Ariston Margherita ALD12 3 Flashes
    its a heater / thermister / board fault
    1st two are easily tested, the board not so
    #208277
    Please try not to post the same question twice, it makes things messy and leads to confusion. I will delete your first post and copy the body of that post here.
    Posted at 6.30 PM by japn.
    Hi there I have had problems with my machine lately so decided to get an engineer in to look at the problem. Originaly the dial was spinning continuously and giving 8 flashes as an error code. the engineer then told me that the circuit board needed replacing.
    after the engineer replaced the circuit board the machine still does not run but this time displays 3 flashes and he told me that the motor is finished and not cost effective to repair so to get a new machine.
    when I asked him what exactly was up with the motor, brushes or burnt out he gave me a kind of not confident reply and just said it had packed in.
    so I promptly decided to investigate for myself to find the back cover had been left off the machine with several screws left on top of the machine. I can only asume that he took the parts he had ordered back and refitted the original back but why have I now got 3 flashes instead of the original 8.
    Is there a manual available for this ald12uk that I could repair the machine myself. I am handy with a multi meter but just need to know what I should test and what should the expected readings be.
    I hope you can help because somehow I think I am being fiddled. is there a reset procedure I can try. I did read about a red do but mine look blue or green.
    any help appreciated
    #208278
    japn
    hi there How do I go about testing the first two items please.
    #208279
    japn wrote:hi there How do I go about testing the first two items please.
    With your multimeter you should have approx 25-30 ohms for the heater and 22 Kohms for the thermistor! 😉
    #208280
    japn
    sorry this will sound like a stupid question but where is the thermistor located. I have not got my multimeter with me today but I did check two terminals at the back of the machine which looked like they could be the thermistors and they gave me a reading of about 34 ohms. also looked like main heater elements were in a metal duct on top of the machine. they also checked out I recon. there was a square unit on top that looked like a voltage transducer that did hace a loose terminal also not sure if it is used to supply the heatet elements. is there anything else I can check
    #208281
    japn
    ops meant 34kohms
    #208282
    japn
    To save confusion have you any pictures of the thermistor and heater. or a parts diagram. is a manual available in pdf for this machine as I have lost mine.
    cheers
    #208283
    japn wrote:sorry this will sound like a stupid question but where is the thermistor located.
    Don’t tempt me…. 😆
    But biting my tongue as I type, the heater and thermistor are located at the back of the drum. 🙂
    #208284
    japn
    Cheers mate 😆 thanks for the quick reply. I will try to test these again and check my figures on monday when I can get back into my workshops to get my multimeter. there were two items on the back of the drum which I tested the other day. both of which had a double terminal each but only one wire conected were these the heating elements then?
    :rolls: :rolls: :rolls:
    #208285
    japn wrote:were these the heating elements then?
    Takes a smart man to get past you and no mistake…. 8)
    #208286
    japn
    I here that these aristons are basically rebadged indersits. if so which indersit manual handbook do I need for my machine?
    #208287
    japn wrote:I here that these aristons are basically rebadged indersits. if so which indersit manual handbook do I need for my machine?
    You can only obtain a ‘user operating handbook’ as was originally supplied with your machine direct from Ariston. Ring them, give them your model number and if they still hold copies no doubt they will supply. 😉
    #208288
    japn
    Hi there again. I have now tested my machine again and the readings are as follows:
    Heater = 31ohms
    Thermistor = 31 KOhms
    taking the above readings into account does this mean that I need a new thermistor. If so how much will one cost. and how quick for delivery to the channel islands.
    I would just like to be v/careful as my previous fault code was 8 flashes but now showing 3 flashes and the engineer who looked at it for me suspected the motor. please confirm readings as I would like to maybe try to fix the problem.
    any help gratefully appreciated 😀
    #208289
    japn wrote:please confirm readings as I would like to maybe try to fix the problem.
    The readings are both fine which indicates to me a possible connection (to the main module) problem and not a component failure? You will need to ensure all the connections are made and all the connectors are connecting?
    A faulty module cannot be ruled out either? 🙁
