Ariston Margherita ALD12 3 Flashes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita ALD12 3 Flashes
Viewing 3 posts - 16 through 18 (of 18 total)
  • #208290
    japn
    Re: Ariston Margherita ALD12 3 Flashes
    Oh so the module might be at fault. I was not sure about the 7 KOhms difference between the expected & Actual readings in the thermistor. thanks again martin. the engineer who told me the motor was at fault said he had replaced the circuit board which I asume to be that module but I will check all the connections. shall I do a continuity check on the thermistor and heater wires between the module & heater/thermistor terminals.
    How much would a module cost to try?
    could the motor really be at fault to cause this problem?
    will get back to you about the module in a tick
    thanks again martin
    #208291
    japn wrote:shall I do a continuity check on the thermistor and heater wires between the module & heater/thermistor terminals.
    Good idea!
    japn wrote:How much would a module cost to try?
    About £80 ish? 🙁
    japn wrote:could the motor really be at fault to cause this problem?
    It cannot be ruled out I’m afraid as errors and error codes are not 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} accurate, especially with Ariston…. 😯
    #208292
    japn
    well I checked out the board and cannot see any damage. all the connections look ok, removed and refitted all the connectors. switched on machine and still giving fault code 3. before I go for a board are there any tests that can be done on the motor or do you recommend a new board?
