ariston margherita AWD 12 selector knob turning
Home Forums Public Support Forums Help And Support Washing Machine Help Forum ariston margherita AWD 12 selector knob turning
  • #15578
    dawn
    my ariston margherita isn’t working. It goes through the cycle and stops before it takes the fabric conditioner. i have checked the filter, there was a penny in it but still doing the same thing after i have removed it. Checked other suggestions on site but can’t fix it. It is not draining the water and the selector knob keeps turning. When i turned it off then off again, the light just constantly flashes.
    S/N40108807680260960030
    Dawn
    #164143
    Simon46
    Re: ariston margherita AWD 12 selector knob turning
    How many flashes when the knob is turning?
    Regards
    Simon
    #164144
    dawn
    Thanks for replying it flashes five times
    #164145
    Your_Uck
    Fault f5 :Normaly machine is not empying, check your filter at bottom of machine
    #164146
    dawn
    I have checked and re-checked the filter and I can’t see anything blocking it, can it get blocked anywhere else ❓
    #164147
    Your_Uck
    Can get blocked in the sump hose (hose from drum to pump filter) or if your machine drain hose is connected to your sink waste it can get blocked there. Power off if going in machine
    #164148
    dawn
    whats the best way to check where the blockage is. I have disconnected the hose to the sink and there is no water coming out but still loads coming out of the filter. is that a clue or am i completely barking up the wrong tree ❓
    #164149
    Can you hear the pump running, Dawn? If not when the machine is drained fully you need to check in the back of the pump chamber by the propellor – hands, knees and torch job. Alternately the pump motor itself may have failed.
    dawn
    how do you look in the back of the pump chamber. Couldn’t hear the pump running so if the pump motor has failed is it expensive to get fixed
    thanks
    Dawn
    #164151
    Its the area of the pump straight behind the filter.
    If the pump has failed, you will need this:
    http://www.ukwhitegoods.co.uk/modules.p … cts_id=392
    Although, you may prefer to have an engineer do this work for you – click the link below.
    dawn
    I called an engineer in the end and it turned out to be a sock, seems i’ve been over filling the machine and it had gone down the front (somewhere)
    Thanks for all your help wish my dishwasher was as easy (see other forum)
    Dawn
