Hi, I have one of these machines and am having problems with the drying cycle. After a few minutes the program knob starts to rotate, at first it was working ok on lower temperatures but now it is across all the temperature range. I have tried the reset [red dot, on/off ] on the program knob as described in an earlier topic and this worked for a couple of days but now to no avail. the power light flashes 3 times in quick succession. I have had the top off the machine and can see no obvious sign of damage. There is a good flow of air from the fan.Would I be right in thinking that the thermistor has malfunctioned and needs replacing. Thanks for any help you can give
Sorry for the long time in replying (internet problems) Where can I find the NTC on the machine? Could you advise on prices for these components also please. Thanks for your help
