Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston Margherita AWD12 Dryer Not Heating
- This topic has 9 replies, 4 voices, and was last updated 19 years, 9 months ago by
bridportblue.
July 10, 2006 at 7:21 pm #19058
bridportblue
ParticipantAriston Margherita AWD12 Advantage Washer/Dryer. Can anyone help my washer/dryer won’t heat up on on the drying cycle. I have fitted a new thermistor and a heater element but still no joy it just won’t heat up. And now i’m getting ear ache!!!
July 10, 2006 at 8:11 pm #181543iadom
ModeratorRe: Ariston Margherita AWD12 Dryer Not Heating
The next step is to check the machine with the proper electrical test equipment rather than replacing parts first. Did you check the element and thermistor before changing, fault could be any number of places, impossible to guess from here, stats, wiring, control PCB, dryer control, etc, etc. Please remove plug if you intend to proceed further yourself.
August 29, 2006 at 7:31 pm #181544bridportblue
ParticipantRe: Ariston Margherita AWD12 Dryer Not Heating
i have now ckecked all the wiring on neutrals and lives for continuity and and the only wire i can’t get to pass current is the (pink/salmon colour) wire coming off of the heater element with the resistor? covered by a heat sleave from which i have 240v on both connections of the heater element when testing back to the incomming neutral connection block. should this wire pass current it also won’t give any resistance. any help would be much appreciated. I am a corgi registered heating engineer and this is doing my headin. 😀
August 29, 2006 at 7:48 pm #181545ampthillmob
This is likley to be the faulty part, it will only show resistance in one direction (if it’s not faulty) if you take off the cover you will see it has a point at one end this shows the correct direction. I have replaced quite a few of this parts recently.
Remember to unplug the appliance and to check that the appliance is not live before commencing workAugust 29, 2006 at 7:55 pm #181546bridportblue
this wire can only be installed in one direction (different connectors) do you know what this parts is called and or the part number? 😀
August 29, 2006 at 8:25 pm #181547Penguin45
Thermal cut out – p/no C00080775. An email to spares@ukwhitegoods.co.uk for prices and ordering.
Penguin45.August 29, 2006 at 8:51 pm #181548bridportblue
any idea why this would stop working just to pre’empt any future a problem. 😀
August 29, 2006 at 9:01 pm #181549Penguin45
Overheat situation. Condenser housing full of fluff is always a good bet. Beware of very sharp edges if investigating.
August 29, 2006 at 9:05 pm #181550bridportblue
😀 thank for the info have cleaned out the fan housing and as far down the drum as i can get but that was after it stopped working i’ve emailed for the part so fingers crossed eh. thank again i’ll keep the site posted. Top Site 😀 😀
August 29, 2006 at 9:20 pm #181551Penguin45
Condenser housing is the big plastic moulding under the fan housing. Defo worth investigating.
