Ariston Margherita AWD12
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita AWD12
Viewing 3 posts - 16 through 18 (of 18 total)
  • #113429
    dimo
    Re: Ariston Margherita AWD12
    What is the right procedure for RESET?
    May be I do something wrong there.
    #113430
    Dave_Conway
    The 3 flashes you describe means you are probably half way through the reset procedure.
    Turn the washer off, then turn the dial to any black dot. Now turn the washer on and you should see the power indicator light flash 3 times. On the third flash turn washer off again and select a wash programme. Turn the washer on again and after a couple of seconds the machine should start.
    That’s the whole reset procedure, if that doesn’t work there is something else wrong.
    #113431
    dimo
    Thanks Dave, I’ll try it later on.
