Ariston Margherita AWD125 – dial rotating & 7 flashes
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita AWD125 – dial rotating & 7 flashes
  • #46223
    aristonuser
    My Ariston Margherita is 7 yrs old. After selecting a wash, the machine attempts to fill then the dial starts rotating and the light flashes 7 times. Please tell me what this error code means in laymans terms?! Should I call a repair person or is it time to replace it? Many Thanks!!
    #288617
    Re: Ariston Margherita AWD125 – dial rotating & 7 flashe
    It specifically means that the heater relay on the computer board is stuck. You need to check the heater for resistance and the wiring for continuity with your test meter to eliminate them from your enquiries; if OK, the board is the culprit.
    aristonuser
    Thanks so much – we’ll call the engineer!
