Ariston Margherita CDE 12X Flashing Light Problem !!!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita CDE 12X Flashing Light Problem !!!
  • #40283
    howard_b
    Pleaseeeee Help me !!!
    You guys have been really helpful with similar queries in the past, so am really hoping you can kindly help me again.
    I have an integrated washing machine, Ariston Margherita CDE 12X. It has been really playing up and doesnt seem to want to complete its wash cycle.
    It is now giving me a red flashing light that is flashing 5 times.
    Can somebody please tell me what this means, and ideally what I can do to fix it?
    Prior to the light flashing, the wheel that you twist to set the wash program just continually turnround and clicked. Even when I powered off the machine and turned the dial to the red dot then switched it on again, the light just flashed really quickly in now obvious pattern. ….. At least, now I am getting 5 flashes of the light.
    Thank you VERY much in advance if you are able to please help.
    Howard
    #265624
    helo_75
    your pumps blocked
    empty the filter and pump housing, and youll be fine
    plug out if you plan to work on the machine
    #265625
    howard_b
    Re: Ariston Margherita CDE 12X Flashing Light Problem !!!
    Thanks so much for that – much appreciated !!!
    however…being as naive as I am…. would you be so kind as to tell me where the pump and the hose is located? I assume I need to whip the lid off and the pump will be accessible from there, and the hose will be obvious once I have located the pump ?
    thanks again in advance
    #265626
    helo_75
    no, its on the front, there should be a filter, possiby under the kick strip at the front!!!
