Ariston Margherita CDE 12x Washing Machine
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita CDE 12x Washing Machine
  • #9147
    My machine is 3 years old and has a usage of about once a week. Recently we have noticed that there is water in the drum. A couple of hours after a wash cycle clear water starts to appear and at times it the level comes above the door. I’ve checked the filter and its ok. If a set the selector to drain the water is pumped out but more appears in a couple of hours. As a test I’ve turned off the hot and cold water supplies, one at a time, and the problem only appears when the cold water supply is turned on. I think this must indicate a faulty electro valve in the machine.
    I’d appreciate if somebody could confirm this and tell me how to fix it. I’ve searched the web but can’t find any reference to this model and there doesn’t seem to be an Ariston web site for Ireland and the UK???
    Thanks in advance
    Anthony (Ireland) ❓
    #132659
    Re: Ariston Margherita CDE 12x Washing Machine
    It is almost certainanly the cold fill valve usualy a double solenoid valve, if you look up the web for. theservicecentre.co.uk you might get help for part required.
    #132660
    Dave_Conway
    It’s a three way valve on this machine, part number C00087975 at £17.13 inc VAT and delivery (ROI not a problem).
    If you’d like one, email to spares@ukwhitegoods.co.uk please 😀
