Ariston Margherita – Selector clicking round
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston Margherita – Selector clicking round
  • #37677
    vaultsman
    Ariston Margherita 2000 AWD 12 Advantage Washer/Dryer
    The machine is around 6 years old and works OK on the #8 40C program. If i try to use it on, say, the #1 program the machine starts to fill then the power light goes out briefly then flashes 8 times.
    I’ve read a few threads which suggest it could be a number of things including control module, pressure switch, etc, but I’m a little confused by the fact that program #8 works OK?
    I’ve cleaned the filter, checked the pressure switch works by sucking/blowing, the drain hose seems OK in the standpipe.
    Any help would be appreciated. (Great site by the way! 🙂 )
    Thanks,
    Stan
    Leicester
    #256021
    helo_75
    heater relay on pcb sticking
    requires both pcb AND eprom , possibly a smartcard if the eprom isnt available anymore
    i think program 8 doesnt use the heater, thats why
    gets expensive
    #256022
    vaultsman
    Re: Ariston Margherita – Selector clicking round
    Thanks helo,
    I’m using program 8 with no hot water available for filling (price of gas? 👿 ~) i.e cold fill only. Wouldn’t the heater come in then?
    #256023
    vaultsman
    Just been searching again for “eight flashes” in the light of your reply…does seem to confirm it’s the heater relay.
    Only a cheap machine I know, so probably not worth the engineer’s time? Sounds from other threads the PCB’s crap and probably terminal..but is it worth me seeing if I can “unstick” the relay? Whilst I’m saving up for a new machine of course! 🙁
    If so, how do I get at it?
