Ariston MBA3842c
  • #32423
    timjam
    Hi I have been to see this Fridge Freezer, Cust says that fridge temp is getting to about 10c then freezing food. is this likley to be thermistors ??
    #235097
    Re: Ariston MBA3842c
    Can be decalibrated fridge thermistor… but I wonder if shouldn’t give some error (if compressor not stopping=does not reach setup temperature).
    Can be also fridge fun triac from PCB shorted…
    or: COMBI is placed outside? (ambient temperature is below zero degree) on PCB is the fourth sensor which is for ambient… 😈 :snigger:
    #235098
    johnnyj
    I’m sure there is a timed module to cure problems of thermistor going out of calibration, i,ve fitted a few for this fault i’m sure it was that model, the only one i had problems after fitting, was in an old large house and the ambient temp was on the low side, and the fridge froze everything due to it running on a timer. I’ll have a look for part n/o to-morrow cheers jj Part n/o is 2503982 though it ihas been
    superseded dont know the supersision n/o ‘
    #235099
    Simon46
    Any luck with module part number? Have one to repair.
    S.
