Ariston type CM01XE s/n 210300264 after cooling down the fridge part(uper) to the set temperature he close the trap(I do not know the definition) and compresor continuing the work until rich the set temp. for freezer. That’s OK. But after that he don’t open the trap for air to cooling the uper side even temperature rich chamber temp +24degree. No error when have +24’C 🙁 for fridge and -21’C 🙂 for freezer and compresor is in relax pozition. 8)
Any direction or service manual is require. ❓
Baron
Hi all, I received in night an suggestion from merloni service how to check this malfuction which allready exist in database(service manual). It meens the corespondence between temperature and resistance of temperature probe(sensor) and if its decalibrated just on the main PCB to make an strap(SCC) between pins 5 and 6.
I will try today and say whats happend. Cheers
Re: Ariston MBA3842C fridge-freezer no error on malfunction
😯 Thermistor was decalibrated, it show at chamber temperature (24’C) the resistence 5.7KOhm( at that temperature must have aprox.2.6KOhm). I made the short between pins 5&6 (counting from left side). Work fine for 36hours allready.
