Hi have this fridge that the customer says the temp is not cold enough. on the display it shows +2 and the temp seems ok. She says that the fan sometimes doesn’t work. I have measured voltage to the fan and have about 50volts. The only thin i faoun is that there is no ventilation above sholud have at least 10cm. could this be the problem.?????
