Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Ariston Nightmare
- This topic has 8 replies, 5 voices, and was last updated 18 years, 9 months ago by
mentalmummy.
June 16, 2007 at 1:07 pm #28187
mentalmummy
Participant:rolls:
Hello I hope you can help me. Have had really good advice in the past.
My Ariston washing machine stopped during a program and had lights flashing I think three on each side and I was unable to open the door.I tried a quick 30 min wash to see – I know..impatient! – and it started to fill then stopped again. It won’t drain, it won’t spin. I have managed to open the door by unplugging at the mains – along with all the water !! – and have emptied the load – which was quite heavy – towels bath mats etc – tried to drain again but no joy. It clicks on like it will drain and just does nothing. All pipes seem clear of blockage – any advice would be gratefully recieved – 4 kids and a weeks worth of school uniform to wash !!
Cheers Tracy.June 16, 2007 at 1:15 pm #217287mentalmummy
ParticipantRe: Ariston Nightmare
Sorry me again – forgot say it is an Ariston A1636 and now just two lights flashing and the on/off button. Cheers, T.
June 16, 2007 at 1:23 pm #217288helo_75
Participantwhich 2?
if you count, obiously light1 is 1, 2 is two, etc
which 2 are flashing (i.e 1+2 3+4 1+4 etc)
thats the fault code
thanx
June 16, 2007 at 1:26 pm #217289mentalmummy
Hiya – Thanks for the reply. It’s lights 2 and 4 – this probably means I do too much washing and its had enough !!
Thanks again,
Tracy.June 16, 2007 at 1:38 pm #217290helo_75
Participantf05 – pressure switch stuck on full
this could be quite a few things
1st of all, the pressure switch could be faulty
the pipe from the switch to the pressure bottle could be damaged/kinked
the pressure bottle itself could be clogged up with gungefailing that, its the pcb!! (which will require a new eprom as well)
PLUG OUT if your gonna check it yourself!!
hope this helps
June 16, 2007 at 6:44 pm #217291hotpnt
hi, b4 you go too deep, if you were washing bath mats were they the rubber backed type? as it sounds like pump is blocked somewhere as you say it would not empty at all
June 16, 2007 at 9:50 pm #217292indespoint
Come on guys the hint was it doesnt drain. The pump is bound to be jammed hence the flashing lights no matter which ones are flashing.
Best way to deal with it is to get your hubby to pull machine out get drain hose into a bucket and allow it to drain through gravity. Once you’ve got all the water out you can open door without flooding kitchen and remove clothes.
June 16, 2007 at 9:54 pm #217293hotpnt
hi inde thats what i was trying to politely say 😆
June 16, 2007 at 11:41 pm #217294Penguin45
This is a Hotpoint/Indesit hybrid machine. There will be a filter in the sump hose connecting the drum and the pump. Remove rear lower cover for access. Power off, of course.
