Ariston Oven Door
  • #7640
    JF77
    I have built in Ariston Oven model FM87,
    and have ordered and recieved a new inner door to replace the old one.
    Does anyone know how I get the old one off?
    There appears to be some screws on the bottom edge but are obstructed by some silver trim.
    Help greatly appreciated!
    J ❓
    #124402
    Dave_Conway
    Re: Ariston Oven Door
    Have a look around this forum J
    There’s a couple of recent threads regarding oven doors etc and Ignis and Whirlpoool one’s spring to mind, they are much the same in removal etc.
    #124403
    XoioX2000
    Hi there,
    I have finally found a small video which shows how to remove the door of the Ariston FV37 GB
    http://www.bshappliancecare.com/Bosch/Bosch_47620.html
    It is from the Bosh web site, but if you look at example 2, it is exactly the same hinges as on the FV37 GB.
    The only thing was that the clip on my oven were so sticky I had to use a thin flat screwdriver to lift them.
    Good luck!
    David
    #124404
