Evening/Morning all,(depending on when you’re looking)
The screw in TOC back, top left on the main (lower)oven is shorting to earth on this one. It’s the main oven cut out.
Not sure of the rating (if indeed it’s stated anywhere) or if another one will do (190 deg C00041159??? that I’ve found) but Connect are out of stock of what looks like the right one 5031682016596.
Could a kind soul with Partfinder have a look for the part number for me…….Ta!!
But just in case it is a DOV317 I will send you a screen dump. There are two totally different models, one made by New World and one by Stoves. You will need to ID the correct one first.
