Home › Forums › Public Support Forums › Help And Support › Cooker And Oven Forum › Ariston Oven FV242 – won’t heat (grill/fan ok)
- This topic has 5 replies, 2 voices, and was last updated 18 years, 8 months ago by
rss.
August 10, 2007 at 7:53 pm #29672
rss
ParticipantHi all,
we have an Ariston FV242 oven which we inherited when we bought the property back in Feb this year. Earlier this week the oven failed to heat and no matter what knobs I twiddle, it still wont!
The grill is ok and the fan works. Other than that it is a very simple oven with no electronic controls etc..
I’ve removed the oven from the kitchen unit (at least the builders put a plug on it). Any ideas on what I should next ? Is it repairable or would it be easier to buy another cheap oven (we are having a new kitchen fitted next year so I don’t want to be spending huge amounts of cash).
Thanks in anticipation!
Russ.August 10, 2007 at 7:58 pm #224064Penguin45
ParticipantRe: Ariston Oven FV242 – won’t heat (grill/fan ok)
Have a read of this:
http://www.ukwhitegoods.co.uk/modules.p … ge&pid=103Then buy one of these:
http://shop.ukwhitegoods.co.uk/advanced … 3e&x=7&y=9Should sort it for you.
Keep that plug where you can see it and not in the socket.
Penguin45.August 10, 2007 at 8:32 pm #224065rss
thanks very much for the reply. One thing I didn’t mention was when the oven started playing up, there was a piece of foil obstructing the fan ventilation. Could this have caused the element to overheat ?
I presume the main oven has an element in addition to the grill? If so how do I access it ?
thanks
Russ.August 10, 2007 at 8:40 pm #224066rss
OK, answered my own question. Inside the oven I’ve undone the 4 screws and removed the plate at the back and now I can see the exposed element.
So I guess it is take this one out, order and spare and hopefully that will cure it !? Anything else that I could/should check/replace at the same time?
Russ.August 10, 2007 at 8:52 pm #224067Penguin45
rss wrote:One thing I didn’t mention was when the oven started playing up, there was a piece of foil obstructing the fan ventilation. Could this have caused the element to overheat ?
Definitely – if the air flow to the fan gets restricted, the element will overheat and blow in pretty short order.
As for the rest of it, check fan is nice and free and get rid of any grease deposits whilst you’ve got the access.
Ideally, you should check the resistance of the element (unless it is visibly broken, split or “fizzed”) with a test meter. A reading of 20-40 ohms would be normal.
August 11, 2007 at 12:55 pm #224068rss
ok checked the element and it has gone open circuit so will order a spare.
thanks very much for your help.
Russ.
