ariston w/d awd12s
  • #48965
    A1phil
    hi ariston w/d awd12s select any programme starts pumping door lock starts to flash then prog knobs starts to continually turn checked components ie heater motor etc all seem ok.thinking control board any ideas, thanks
    #298322
    Re: ariston w/d awd12s
    When the timer knob starts to click round you need to count how many times the mains light flashes between pauses, that will give you an error code.
    Deleted your duplicate post in the public forums BTW. 😉
    iadom wrote: that will give you an error code.
    Which may or may not be much use :rolls:
    That specimen has done well to last this long! Must be an old lady using it once a week and living in a tidy, dry and well insulated bungalow.
    You could do a search on here in Trade Technical Enquiries using just the model no. You’d probably find enough to keep you entertained for hours and on and on and on…
    Mike.
    #298324
    A1phil
    thanks
