older style. fault no spin, put on spin starts to turn then next click on timer. motor stops , keeps pumping.brushes .motor seem ok ckeckd preesure switch. ok am thinkin module, took owt no burn marks.. timer or module what you hink guys? 😆
Would re-check module closely. Maybe some little give-away mark somewhere. If not, could send to EMW for test/repair. Not sure how they work charge if no fault found. Check first.
New module at Connect only £26 but you’d be lumbered with it if no cure.
Mike.
