ariston w/dryer cde12xuk
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts ariston w/dryer cde12xuk
  • #64898
    petalpop
    went out to one of these
    door seal front lip ripped
    took model number
    when i look it up that model has two door seals
    one with a sprung clamp band
    one with a wire + hook band
    do both seals fit all tubs or do you have to get the correct one
    cheers guys
    #358410
    suedehead1
    Re: ariston w/dryer cde12xuk
    you need to get the right one they arent interchangeable.
    #358411
    You have to fit the correct one, the groove in the wire clamp seal is not big enough for the sprung clamp band.
    You could order the C00094091 and a new spring clamp, C00092195, much easier to refit.
    petalpop
    so the one with the spring band will fit on a tub if it had a hook band originally
    as long as i fit a sprung band as well
    #358413
    AFAIK yes. Partfinder does not mention serial numbers for the different seals, only fixing methods.
    #358414
    petalpop
    i have ordered the seal and spring band
    i will post the result
