Ariston W/machine wont start LEDs flashing indicating Fault
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Ariston W/machine wont start LEDs flashing indicating Fault
  • #32625
    DickBob
    Hi, Hope someone can help. Have an Ariston AVL129EX machine. Machine won’t start cycle. Timer Delay, Super wash and Door Lock LEDs flash. Manual says this indicates machine fault. Was hoping that people might know the common causes of this fault, for me to investigate.
    Thanks in advance.
    #235804
    helo_75
    in order, 1st light being 1 , second being 2… which lights are flashing, ie 1 and 3 etc, ignore the lock light
    probably pcb, normally is
    #235805
    DickBob
    Re: Ariston W/machine wont start LEDs flashing indicating Fa
    Hi. Top LED is Timerdelay, next down is superwash. Both LEDs flash together.
    What is the common PCB fault? Dry joint?
    Cheers
    #235806
    1+2 = F12 = Communications error. Invariably a board fault – Helo does have telepathic powers…….
    Time for help – use the link below for a UKW engineer in your area.
