Re: Ariston washer
‘Cough’ http://tinyurl.com/z29qs
As you have not given us any real info this will have to be a guess. F08 is almost certainly the same as ‘8 flashes’ supposedly 😥 a heater relay fault. In reality it can be a failure in one more components such as module, NTC,pressure switch, loose or faulty wiring etc. An often difficult fault to resovle even for the experts. Would advise seeking help, check the link in my sig to see if we have someone who can help.
If you do a forum search for Indesit/Ariston & 8 flashes you should get an idea of the problem.
