Ariston washer dryer drain pump required AI1259MC
Home Forums Trade Technical & Spare Parts Forums Trade Spare Parts Ariston washer dryer drain pump required AI1259MC
  • #100427
    boselecta
    Hi Guys,
    I require the drain pump for this old washer dryer, its the old shaded pole type pump that’s leaking.
    There used to be a plastic housing you could buy from Qualtex that you could fit an ascol style pump on to as the alternative but I cant find it anywhere
    Does anyone know have one or even have the genuine part?
    #480570
    that pic look a bit like the old hoover pumps from the 80,s
    have you looked at pmp 666 from connect ?
    murv
    C00027465 – Ransom spares list it as in stock?
    Murv…
    #480572
    yes saw that one murv, also saw the price lol
    murv
    Will check what options I have in stock a bit later. I remember seeing the red Hoover pump recently.
    Murv…
    #480574
    murv
    I have a Mainox Hoover shaded pole pump.
    Inlet 38mm
    Oullet 30mm
    Chamber can be rotated to virtually any position
    Stator can be rotated 180 degrees to match the original
    Not sure if the Ariston pump has a 35mm inlet (38mm may be a bit of a stretch)
    If you can give me an email address I can send images.
    Murv…
    #480575
    murv
    Photos are in your mailbox.
    Murv…
