ariston washing machine a1636 flashing neon Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › ariston washing machine a1636 flashing neon This topic has 2 replies, 3 voices, and was last updated 18 years, 5 months ago by lyndy. Viewing 3 posts - 1 through 3 (of 3 total) Author Posts October 16, 2007 at 1:12 pm #31421 lyndyParticipant any ideas how to sort this problem rapid neon and door lock neon flashing within 10seconds of starting the machine on an ariston a1636 wahing machine October 16, 2007 at 3:02 pm #231125 senseibParticipant Re: ariston washing machine a1636 flashing neon Hi Lyndy, Welcome to the happy band 8) You need to indicate which neon light is flashing counting from top to bottom or from left to right as this can establish a fault code! – but more than likely it’ll be the power module 🙁 Yet another job for EMW i guess :rolls: HTH, Brian. October 16, 2007 at 4:02 pm #231126 iadomModerator Re: ariston washing machine a1636 flashing neon In the known error codes thread, page #3 post by Dave Conway. Error F01 motor triac fault, as Brian says, it is the PCB. 😥 However, Check the continuity of the motor, field coil pins 3+5, armature pins 1+2. Check module connector block J9, motor plug and the wiring between them. If they are Ok then it is the module. I will delete your other post to save any confusion. Jim. Author Posts Viewing 3 posts - 1 through 3 (of 3 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
