Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Ariston Washing Machine Mod. A1635 (Margherita)
- This topic has 6 replies, 4 voices, and was last updated 19 years, 6 months ago by
Ashby.
October 3, 2006 at 5:29 am #21347
Ashby
ParticipantMorning all, This machine will spin without a load, but wont spin with a load.The timer continualy rotates. Tryed reseting several times. Eventualy i got it to spin and it made a very loud knocking noise on a fast spin.Bearings seem ok, can’t find anything loose. The machine is about 4 years old. Is this one of the machines that has module problems?
Thanks.
AshbyOctober 5, 2006 at 2:54 pm #190521admin
KeymasterRe: Ariston Washing Machine Mod. A1635 (Margherita)
How many times power-LED is flashing during programer rotation this is one question…
For the second problem about noise when is not bearings:
The most common faulty when you hear the knocking is the broken pulley.
Forward you have to check: shock absorber supports; Counter weights; motor support and the last object is the integrity of drum(damaged)(only opening).October 5, 2006 at 3:05 pm #190522Martin
ParticipantRe: Ariston Washing Machine Mod. A1635 (Margherita)
Ashby wrote:This machine will spin without a load, but wont spin with a load.
As Baron asked….how many flashes are you getting when the dial starts waltzing around?
Even without that info, I would suspect the motor or motor brushes are the cause?
Ashby wrote:and it made a very loud knocking noise on a fast spin.
Again as Baron commented, check the pulley, but more than likely it’s got to be a broken spigot arm and time to consider the WEEE Directive as an option! 🙁
October 5, 2006 at 3:10 pm #190523admin
KeymasterIndeed…
October 6, 2006 at 9:17 pm #190524Ashby
Hi Martin,Baron.
Thanks for your reply.I’ve checked pully,counterweight they look ok. The shock absorbers could do with changing though. I’ve tryed washvac and Masterpart both say they’re speacial orders 10 days plus. Do you know of anywhere i could get them quicker? Masterpart have given me a part number C00086515?
Thanks for all your help.
Much appreciated.
AshbyOctober 6, 2006 at 9:30 pm #190525Dave_Conway
In stock @ Connect Ashby but if you don’t have an account they won’t give you any discount 🙁
Let me know if you’re stuck, I can get them for you either from there or directly from Indesit for you 🙂
October 6, 2006 at 9:36 pm #190526Ashby
Thanks Dave, I have an account with connect i’ll try them. I just assumed that they would say the same.
Ashby -
