AristonAIB 16
  • #11468
    robbra
    hi all
    fault F10 on the above…says p/switch.
    Tried that , had main board checked, ok. any ideas please?
    Thanks.
    Rob
    #145455
    Re: AristonAIB 16
    If you have plugged in a new Pressure switch? and have had the control module checked out OK then you will have to check out all the other obvious troublespots.
    Check things like : Air hose leaks, heater down to earth, NTC open circuit. Pump open circuit or dodgy motor??
    It’s ‘poke and hope’ on these beasts after all. 😕 Indesit engineers throw parts at these machine in a desperate attempt to locate faults. You most likely will have to take the longer route or walk away from it. 🙄
    #145456
    robbra
    Re: AristonAIB 16
    thanks Martin
    Never had this before so will try the lot although it isn’t an air leak as it is F10 as soon as switch on. Wish me luck and I will let you know.
    Rob
    #145457
    andy2
    Re: AristonAIB 16
    I had this fault once and it was a break in a very narrow track on the edge of the PCB.
    Andy
    #145458
    simonb
    Re: AristonAIB 16
    does it spin ie. do a reset and select spin to see if motor is working. again with pump only, not too sure on this model but most fill on 1 valve and then pause for few seconds and then the other valve long shot its not giving up on second valve another thing check out thermister and heater and heater wiring close to heater iv had a few with breaks near heater
    also if brushes are very low this causes problems normally no fault code just sits there sort of thinking but confused and cant think of a fault code to throw at you
    other than that its a lump hammer
    simon
    #145459
    robbra
    Re: AristonAIB 16
    Thanks for the help.
    Gave up in the end after another hour testing everything. Considered the hammer but she was watching
    Rob
