Arms not spinning
  • #41892
    mercurystar999
    I have a Diplomat dishwasher but the arms do not seem to be spinning. I can’t find a model NO on the appliance.
    Is it worth putting that pump in or just buy a decent dishwasher to begin with! It was inherited to us as an integrated appliance when we bought the house.
    #271660
    karv
    Re: Arms not spinning
    model number normally on side of the door in print or label.
    main reason for both arms not turning are that the spray arms holes are blocked. if not then most likely to be wash pump/capacitor depending on model,or module aborting the program before it gets to the wash.
    #271661
    mercurystar999
    Water is coming out of both arms but when i quickly pull down the door they don’t seem to be moving. I put them in a certain place push the door closed and then reopen after 30 seconds or so and they are in the same place.
    #271662
    mercurystar999
    Model NO. ADP8242
    #271663
    If the rotor tips are clear, it’s probable that you’ve got a blockage of some description, or that the circulation pump impellor has sheared off the motor. Nothing for it but pull it out, put it on its back and start looking. Impellor set is available as a spare part, so you don’t have to buy the whole motor.
    It’s a SMEG-made machine, BTW. The housing/impellor set is p/no 690070483, spares@ukwhitegoods.co.uk will be able to get you one promptly if required.
    Power off first,
    mercurystar999
    How much do you think the parts will be?
    #271665
    Hi mercurystar,
    Link to the part here
    HTH
    mercurystar999
    How reliable are these machines? I fear that repairing this machine will only result in me paying out again in the near future?
    #271667
    Your call…… A lot of independents don’t like SMEG machines, mainly because they are misunderstood. I myself am a happy SMEG dishwasher owner of some years.
    I’d drag it out and at least see if you can work out what has happened. It’ll cost you time rather than money and it’ll probably be more interesting than Christmas shopping! You’ve got no chance of replacing it before Christmas, so repair is currently your only option. Apart from the Marigolds……….
    mercurystar999
    Bought an AEG, can’t beat the Germans!!?
    #271669
    It’ll be Polish, or possibly Italian…….
