Re: Arrow built under cooker door problems
Hi Squidge
some of the arrow/teba ovens required a pin to lock the hinge in place before you removed the door, they did come with the appliance but no doubt they have been lost, two small wire nails abt 1 ince long will do the trick. open the hinge using a towl to stop it hurting your fingers and be careful not to trap your fingers, when fully open you will see a small hole, just insert the small nail and repeat for the other side, refit the door take out the nails and you are sorted. 😀
good luck 😉
Bob.
